Space Ace Dedicated Sideart Scan
mlenardon
Thunder Bay, Ontario, Canada
If anyone needs sideart for dedicated Space Ace I just had an old piece scanned and cleaned it up in Photoshop. Thanks goes to Roy Bailey for the original pieces. Sadly the glue had aged so the original art was not usable on my cab. I had a set printed locally for around $110 with a protective coating. Process was have it printed on adhesive vynal, plotter cut and then coated with a slight textured mat finish polycarbonte to make it durable and easy to apply. The original art did not have a coating and was glossy which did not stick or clean well. This art can be wiped down and is thick and shows no bubbles or imperfections. It came out great. I applied with windex. Please do not sell the file but use it for restoration purposes. I will release a scan of the header as soon as I have time. Since there are so few Ded SA cabs out there this will complete the artset available as Quarter ARcade still has the CPO. Speaker plexi as also available from AR/Quarter arcade, repro annunicators and scoreboards for dedicated were available via Mark Spaethe.
Michael
<a href="http://hotfile.com/dl/131961409/6596213/Space_Ace_Ded_sideart_ready_to_print.jpg.html">http://hotfile.com/dl/131961409/6596213/Space_Ace_Ded_sideart_ready_to_print.jpg.html</a>
OK this is better
+1. Glad to grab, even though I don't have a Space Ace. Having high-res art is never a bad thing...
