115 volts are the one of those read 60volts. I have lost power somewhere but i couldn't go much farther till i got the manual.
I think i am following you. Wonder why one measured 115 and one 60 when i was using the same ground?
Ok, from the book it looks like this lug should have 115 volts.... brown wire with orange. Mine doesn't... so is the transformer bad?
If your meter is on AC volts...you should have approximately 115 volts across those two top lugs....the one you pointed to, and the one beside it. That supplies voltage to your monitor. If you hear the "crackle" of your monitor turning on, that voltage is probably fine. Alternately, you could check the voltage at the monitor's power plug. It's basically the same point, thus same voltage (and much easier to get to....though, there is a fuse between these two points).
Edward
