The door and frame itself are the same and will fit. I just looked at my TSPP and Iron Man and the service/menu buttons are different. The Whitestar system (TSPP, South Park) uses three buttons. The SAM system (Iron Man, new Sterns) uses four. The coin switches, lamps, slam tilt switch, etc. should all be the same, but you'll need to figure out something for the extra button that the SAM system uses. I didn't compare the connectors and pin outs, but hopefully this helps some.
