Source for Vision Pro / Wells 19K7302 degaussing connectors?
brokentoken
Donor 6 years: 2019-2024
North Carolina
The headers on these things seem to be a couple millimeters narrower than the ones used on most K7000s. The header pins are the same diameter as standard K7000s.
I haven't been able to locate a source for the housings and pins - anyone know where I can find some?
I did that for one of them...Unfortunately, I have 3 more I'm going to connect to TV tubes. The ones on the TVs are too small to fit around the header pins.
I usually cut them off the old tube or it just comes with the degauss ring from the swap.
Might be tough to find an exact match, I'd just find something from a donor tv or dead monitor.. I've actually made up connectors from scraps in my shop or just junk hanging around.. As it doesn't matter how it looks, just connect it :)
Hell I just made one out of a female snap connector :)
Oh so close to my 2.35mm LVP series plug on this page:
http://www.greatplainselectronics.com/Category-146.asp
The one you want would be a 2362H type plug (black = UL94V-0, Gray = UL94V-1). Same as the LVP-02 but has 8mm spacing for first two pins rather than 10mm. The 2362H also uses the same crimp contacts as the the LVP plugs. I'll look into stocking these with my next connector purchase (several months away).
Board mounted wafer connector would be 2362W-02
Ed
Thanks for the replies, guys.
Pete, I like the Macgyver approach...but wanted to see if I could find the real deal first!
Ed, I loaded up on your LVP plugs when you got 'em in, and have been using them for the yokes and power on these things. I think maybe the easiest path here might be to use a couple of the single pole ones on the one I need right now, then wait to see if you get the new ones in.
Thanks again, and I'll keep watching your site!
