Source for low-res vertical monitors
IdahoFarmer
Donor 3 years: 2012, 2019-2020
Eagle, Idaho
Anyone have a good source for low-res vertical monitors?
Or for that matter... monitors of all types.
Only criteria is I want to stay as close to original as possible... so no lcds.
There's no such thing as a "vertical monitor". Hopefully that will make it easier for you to find one.
That's not "quite" accurate. A horizontal and a vertical K4900 are the same, electrically, but the frame is different. Same with the Sanyo EZ - most of the ones I've seen are vertical, but I've seen horizontal frames, also.
Which makes a big difference on some cabinets how the back door is situated. Last Centipede upright I worked on had a "vertical" monitor. You could have put a standard "horizontal" monitor in it, but then not been able to close the back door.
Yeah, I guess you're right. The cabs I've encountered have had the tube bolted directly to the cabinet, I've never dealt with a frame so I didn't even think about that.
