source 20 pin test clip with ribbon cable
creepykenny
Meridian, Idaho
looking for one 20 pin test clip with a ribbon cable around 18-24" - ideally needs a 20 pin dip on one end but i believe i can add one of those myself, in fact i don't even need the test clip just the cable but i will take what i can get
looks something like 2nd & 3rd pictures attached
There has to be an old computer in your area, grab the ribbon cable for the ide hard drive. If it is 40 pin (ribbon cable) just rip in half. If you want a color coded one PM Buffett.
Channelmanic was selling cables exactly like your last two pictures. I bought a couple from him to use with my Huntron setup. You should see if he has any left.
Last one I needed was for my Bugtrap....
I bought 2 20pin IDC connectors on eBay (these were also used on MFM and RLL hard drive cables (the smaller one)). I then crimped one on the Bugtrap end, then two on the far end and used the inside set of 10 pines off each of the 20 pin connectors on the far end to connect to the 20 pin test clip.
I already had plenty of ribbon cable.... from years of computers/etc.
Worked great.
