dyno
The sound on my escape from the planet of the robot monsetrs is very faint, even when the game is in test mode. The sound worked fine when I got the game but then it cut out and if you listen closely you can hear it, with the volume cranked. I thought it was the tl084 op amp but that didn't fix the problem. It uses a JS Audio board, any ideas? I looked for cold solder joints and have recapped the sound board with no luck.
