Sound Problems Lethal Enforcers 1/2 Cabinet
ninedayfall75
BANNED
La Habra, California
The sound cuts in and out and has a slight static to it. I tried running new wiring, nothing. I own 2 Lethal Enforcers boards and 1 Lethal Enforcers 2 board. All of them exhibit the same issue. I even tried another set of speakers, and same problem. I don't think the sound on all 3 boards is bad, but who knows. Is there anything else I can try to fix this issue? Is there a way to bypass the stereo output and use the Jamma harness to output mono sound, or are these boards not capable of that? I also tried switching the settings to mono and it sounded just as bad.
Thanks in advance.
As far as I know it's the same since this custom chip is the origin of all sounds. I tried both in real life and doesn't help chosing either of them unfortunately.
It is repairable - but that process isn't for everyone. Maybe I'll try some day, but until then this gameboard is stashed away at a dark place...
