Sweet! Looks to be in really nice shape. Did you figure out if it works yet?
Not yet. I need to look it over and lube up anything that needs it.
Remember that EM games are mostly lube free as it is metal on metal and any grease will actually just dry up over time. The only lube that is recommended is a slight smearing of contact disc grease on the rotating unit plates.
DO NOT(!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!) use WD40 for anything inside of this machine! It attracts dirt and things get gross really quickly, but on top of that, it is highly highly flammable in these machines even when dry! I have seen pictures of machines catching fire and burning half of the inside of the game, destroying all of it and luckily not the owner's home too. A whole lot of sparks from arcing contacts + WD40 = fire. Be careful!
