sonyo 20 ez help
toad
Roanoke, Virginia
I have 2 sanyo ez and one has its power cable cut , and one does not, they booth say "AE" and "AF" on the Chassis , and I was planing on swooping the hacked cable for the good cable. what should I do?
Toad
Can some one Please Help Me!!!!!!!!
Responses may take some time.
Anyway, what you could do is remember which cable went where, and swap the cables by unsoldering both cables and re-solder the good one onto the desired monitor. Or, you could find a replacement cable (any type with a wall outlet at the end will work) or an extension cord and cut the female end off and attach to the monitor. It doesn't matter if the connections between AF and AE are swapped. BE WARNED THOUGH! These monitor's operate on 100V AC (Do not plug them into your wall outlet)
