(SOLVED THANK YOU) G07 red turns orangey in corner
This is the one you want.
This is the ring degausser most people use, https://na.suzohapp.com/products/monitors/49-0559-00, what have you been using?
Though if you have a spare degaussing coul from a monitor you can just use that with a momentary switch.
Watch some YouTube on adjusting yoke and purity. Start with purity first. It's the ring typically closest to the front of the tube. Remember to mark you original ring locations with a marker before you start so you have always reset the rings if they get all messed up. Pull the service manual as they will walk you through it. You may get lucky and just have to make a slight adjustment of the purity ring to get the colors corrected. I'd highly suggest removing the monitor and using a test bench. Will make your life easier while doing adjustments. A TPG works great so you can put a solid color on the screen and make your adjustments.
@Buffett
@mecha
@tron guy
And several others here are the pros. I just fumble my way through it from time to time.
Is that board running a HSS DK3 kit?
Colors look off to me.
It's running a d2k on a dk board. Yes the colors look weird because it's a g07. Freshly recapped last year. Board looks fine on my Sanyo. Some weird conversation happens using mikes Nintendo to Jamma adapter
EDIT: It looks better in person btw
Yeah I used to run Braze kits but I found these multi kits that are used awesome.
So calibrate the colors with a TPG? My G07 is the best 19" monitor I have. Much better image than my 4900 and 4600.
Is it's this adapter it looks to have RBG adjustment pots on it. Should be able to adjust the colors.
