SOLVED: k4900 in MCR game doing brightness rolling
arcadeaction
Donor 2013-2014
Gainesville, Florida
Update: using a switching power supply did eliminate all of the dark rolling bands. When the opportunity comes, I'll likely install new caps/parts on the original power supply to attempt to use it once again.
A video didn't show the effect correctly, so I made an animation that shows in better detail to get the idea across.
The monitor has just been recapped with high quality caps. I was wondering if this may be due to a ground issue somewhere or what thoughts might be.
-Basically it is showing dark horizontal bands that move down the screen, and the brightness fluctuates.
-Unplugging the marquee light did not affect it
-Adjusting the flyback screen control did not affect it
-Disconnecting the ground strap to the monitor frame did not affect it.
May this perhaps be caused by the power supply (caps/fuses in the power supply)?
tapper-monitor-gif.607618
