OK, so I took a chance and replaced the HOT with the one I had from my K7000. Not sure if they're compatible since I didn't get a specific answer, but it definitely did something. When I turned the monitor on I got some smoke from the resistor at R167 and it now is all burnt. The screen did actually turn on and has a bright white line across the center. I am reading that this may be because of the remote board maybe? Is there a chance it might work fine if I jsut replace that resistor, or will it jsut do the same thing? What is the value I need to replace it with? IS it something special or jsut a standard resistor? What do I look at now to fix or replace? Does a cap kit address this?
Also am I correct that the POLO 25 doesn't need to be discharged? I'm still gonna do it out of habit, but I was reading that might be the case with this and I wasn't getting a pop when doing it.
