- Joined
- Apr 16, 2012
- Messages
- 25,937
- Reaction score
- 13,048
Also agree with @Onji that you need to check the ground in each socket to a ground in the cabinet, NOT to the other socket.
This is screaming pinched or cracked conductors in the ground to me.
The following is done with the game unplugged from power.
When you are checking the ohms to the ground strip in the cabinet, move the door from open to closed and see if they change. If they do, you have a problem with your ground wire.
If the ohms don't change, repeat this with the 5 volt power wire. Move the door from open to closed, see if the resistance changes.
