acblunden2
-=SOLVED/CLOSED=- What size Compact Flash for Killer Instinct 2?
Most of the resources I have checked online says that you need a 512mb compact flash card to write the CHD for Killer Instinct 2. But when I do it, chdman.exe gives me and error to saying there isn't enough space. My only other CF card is a 16gb card and works fine to replace the HDD (after burning a new boot rom). Seems like a waste though.
What size CF card should I be using? Anyone successfully use a 512mb card? Is there a different command I should be using than:
chdman extracthd -i kinst2.chd -o \\.\PHYSICALDRIVE<insert drive number> -f
