Solenoids for Shooting Game needede
jvanallen
Buckeye Lake, Ohio
I have a Mechanized Attack by SNK, neither gun will shake when you fire it, I believe the solenoids are bad, I have searched online for a replacement to no avail can someone help me out on this, the part number in the owners manual is SD 12AA-24-00 there is another number on the metal casing that houses the solenoid and it is 270301-not sure what that is
Solenoids don't fail often unless the drive transistor goes with it. If the plunger still moves freely in the coil, and an ohm check shows a direct short between each side, then it's probably fine.
Have you checked the settings to make sure they're not shut off? Some games had that option. Also check fuses, power to the coils, etc...
