SOLD - GAME SOLD! Taito 20-in-1 Gameroom Coin-Op Classics 13" CRT Bartop Machine
Emdkay
Donor 7 years: 2011, 2015-2020
Whippany, New Jersey
Rating - 92.9%
13   1   0
This is an original/official release machine from Taito & HanaHo.
[+] PCB is original, manufactured in 2005. This is not one of the newer/reproduction PCBs that's unable to operate the 20-in-1 game image.
[+] SD card is not original. The original SD card contained a 10-in-1 Taito classics image. However, I simply removed it and put in a new SD card containing the 20-in-1 Taito image.
[+] The 13" CRT is flawless with absolutely zero burn-in.
[+] The insides appear perfectly clean. It's been in a completely smoke-free environment for about 3 years.
[+] Mono speaker puts out sound, and all buttons register properly to the jamma harness.
[+] Cabinet manufacture date is 2005 according to the original PCB.
[+] Artwork is all original and in good condition
[-] There is no spinner/trackball support.
If you plan on putting a different board inside:
The cabinet has a jamma harness, so you can swap it out, but you'd likely need to re-wire the controls/harness. Also, you'd most likely need stronger power supply (like the WEI-YA 15AMP arcade switching power supply), as the power currently in the cabinet is only enough juice to run the original Hanaho PCB. This is as much as I understand about the power requirements.
Games on this Taito Gameroom Classics board are:
Arkanoid
Arkanoid 2
Bubble Bobble
Chack 'N Pop
Elevator Action
Jungle Hunt
Liquid Kids
Lunar Rescue
Nastar
Puzzle Bobble
Qix
Rainbow Island
Rainbow Islands Extra
Rastan
Return of the Invaders
Space Invaders
Space Invaders DX
Super Qix
The New Zealand Story
Zoo Keeper
This is the game menu:
Photos:
The board in this machine alone typically sells for $250, so I'm starting off asking $400 since it's a small cabinet and isn't taking up much space right now. I'm not parting it out right now either.
Thanks!
Pretty cool bartop, I don't think I'm that far from you either...
Subscribed. Possibly interested if you end up selling the board.
I'd probably take everything else. Good luck with the sale, i hope it doesn't come to parting it out though.
