farquh
SO I took apart my cocktail table tonight, and man, it was a process! The Q-Bert cocktail table has a unique design, but it's hard to manipulate!
If you've never seen one before, the PCB is on the backside of the main door. So it looks immaculate since it's been protected from direct dust all these years. On the back of the particle board that the PCB is attached to is where the speech board and the power supply board are stored. So, the way this table is designed, it is harder than hell to even get to the PCB board's dip switches!
Finally getting a good look at the PCB, I can now clearly see the grid and the sections designated for E1-2 and such. So, the consensus is that these are the chips that might be in need of replacement? Are such things an easy find in today's day and age?
I will post a video of what my game is doing as well as pictures of the PCB and speech board in a little while.
I hope that my situation hasn't gone from bad to worse with my 'tinkering' since today it has some sound issues. Yesterday, the only problem seemed to be that the 'sprites' were only appearing at the bottom of the screen. And now today (on top of the same 'sprite' issue) things such as the discs do not make any sound at all when Q-Bert jumps onto one and rides to the top of the pyramid. Other things like after Q-Bert gets killed by Coiley the 1-Up sound is heard. Little things like that.
Does this still sound like a fixable problem?
