So at CAX last year there was a super sprint with an lcd type of monitor in it....
tron guy
Super Moderator
Staff member
Donor 12 years: 2011, 2015-2025
Eureka, California
Does anyone know what it would take and what type of monitor is used for that?
It looked awesome, and I've got a paperboy with a dead monitor and no hope of finding a replacement at this point.
What's wrong with your paperboy monitor?
it's an atari disco and it's dead. No picture. B+ measures ok, it's been recapped. Gone over for no less than 10 hours searching for issues.
If you can fix a disco I'm all for it, let me know.
Maybe Chad can fix it?
Here's a youtube of someone using a converter to use VGA computer monitor with an APB:
so it may be as easy as getting that rgb converter (or whatever it is) and hooking it up to an lcd?
A friend of mine just stuck a 19" LCD in his Narc. It looked good. I'll ask him what he did.
Edward
I think it was called "Superer Sprint" or something like that...it was impressive I must say.
One route you could try is to buy a replacement chassis from a place like 8liners.com. I picked up a replacement chassis from them for my Disco monitor that they say will work fine. I haven't actually had a chance to try it yet as my Disco still works well, but I have heard that others in similar situations have bought the same from them, and it worked fine.
Just a suggestion...
Jon
Jon
they say it works for a medium res disco? There are standard res discos like in I-robot, or med res that is in this paperboy.
I like the lcd idea the best. These med res games are the only ones that look good on lcd's. (my opinion)
Superer Sprint
It was this one:
Definitely cool and fun on a big screen, but it wasn't an LCD. It dwarfed mine at CAX last year which was crammed in the back corner :(
-GackAttack
just bumping this to see if someone knows of a good way to handle this switch.
isn't there an CGA/EGA/VGA to whatever adaptor you can get?
I imagine that these are the best way to adapt one signal to another resolution for use on a VGA monitor.
ok I got one of these converters hooked it up and I am getting NO SIGNAL.
I can't get jack shit out of it.
anyone have an idea?
edit: to be clear what I've done.
I connected the wires that would go to the monitor to the converter board.
I connected +5v to the converter board, I'm getting 5.07
I have the lcd computer monitor connected via the vga output of the converter.
no signal, and pushing the SW button to scroll through the different rgb inputs doesn't change anything.
I do have to say once or twice (randomly and for one 1/10th of a second) I thought I saw what I would describe as an unsynced screen.
The converter board has a red led lit, the position is LED1 not sure if that's relevant.
