andrewb
I've put together a very nice pair of LS-30 rotary sticks. These started as a mostly complete pair when I got them (minus the knobs), and are all original parts. They are fully working, excellent condition, and tested.
Note that these also have the SOLID weighted-metal knobs. Not the hollow knobs with the plastic insert. These are a little nicer than the hollow knobs, as they feel heavier and more solid in the hand.
Details:
- I believe these bases are an original pair, as they have the same number stamped on the sides, and have similar wear.
- Both sticks have been completely disassembled, all parts washed + dried, and reassembled.
- During reassembly, I added a TINY amount of silicone grease to all friction points, so the action is silky smooth.
- Upper square restrictor holes are in excellent condition, very low wear (see pics).
- All four microswitches per stick are original, and have been removed, cleaned, tested, and are all working 100%.
- Rotary position switches have been disassembled, cleaned, lubed, and tested.
- Original springs are fully intact, and have been tumble polished (see pics).
- The metal pins and half-circle brackets on the bottom of the sticks are in excellent shape, almost no wear (see pics)
- Includes two original dust washers.
- Includes a pair of 13-pin cables, both tested.
These are in excellent shape, and are in near-matched condition (i.e., they look and feel the same.) You'll be hard-pressed to find a nicer pair, short of NOS.
$350 shipped for the pair, in the US. Int'l shipping extra.
Details:
