Smash TV graphics issue
Shavenyak
Donor 2023
Sarasota, Florida
Any ideas what's causing this? I reseated all the chips but it didn't change anything. I"m getting 5 volts on the board. Thanks!
Run the diagnostics tests from the menu. What do they show?
Hmmmm....
I haven't done that. It's been a long time since I've had this game on. I'll look into it. I know the tests it does at power up shows everything is good. Would the tests you're referring to test other things or show something the power up test does not?
I had a problem with a smash tv board, turned out to be socketed chips. Game looked good until you moved around. then it would leave sort of a trail.. Luckily I had a bad smash tv pcb to swap from.
http://forums.arcade-museum.com/showthread.php?t=141978&highlight=smash
You can probably rob chips from nba jam, some mk1, high impact, plus a few others..
