Small vector birth
dutchman
Donor 2024
Delaware
The government stork dropped this off today:
And after a little playful dress up…
Did I actually need a new WG6100 base plate? No, probably not. Sometimes these little bundles of joy are just unexpected. I even sourced most of the hardware needed.
I ordered a one off to see how well it would turn out so it was pricey at just under $70. The actual goal is to make a 6100 compatible base plate for the 4600. The frame is otherwise very similar so would be a good candidate for converting. If a few people actually wanted one we could get the price down to something reasonable.
1000002615.jpglooks good. I have made new frames as well .
I see you have put square holes on both front and back . I plan to do that myself next run rather than make more PCB brackets.
I've been using SendCutSend a fuck ton for arcade parts.
I have a decent sized order coming to me soon from them.
I went to calculate shipping on a "fuck ton" and I got an error from both UPS and FedEx.
USPS reported a system failure and bombed before I got an answer.
View attachment 829387looks good. I have made new frames as well .
I have the side panels modeled as well but didn't bother getting them produced. Your full frame looks pretty good. I guess you didn't bother with the tube shielding?
The 4600 has slats for a base plate so you would need to bend up the tabs correct?
The thinking is to use the mounting tabs for the slats but not use the actual slats. Although going on top of the slats is another option and would make it easier to allow some variation for different tube clearances.
Not surprising regarding USPS and FedEx. They suck.
Especially FedEx.
