I was just wondering if anyone knew how to fix this. I've got a WG monitor and there's a barely noticeable wiggle on the screen. Is this something that's going to go away as it heats up?
Are you using a transformer with your monitor? If not get one, if you are using one check the voltage on the secondary terminals and see if it's to high if so swap the primary and secondary wires and see if that helps.
