I use a "stock" version of mameUI32v.139 with Mala as the FE. This version of mame has the options in a drop down menu that you can just check off. Works like a champ for me. Took a whole 10 seconds to do...
Or by creating .cfg files like mentioned above.
No... what I said stands true.![]()
I wonder why mine works so well then. Huh. I must have done something wrong!
Dunno. It was my understanding that to get rid of the nags you needed to roll your own version of MAME. Which is what I did. I also added back in high score saves. Maybe you are using an older version of MAME or a GUI version of MAME? I am using the command line version with MALA.
I use a "stock" version of mameUI32v.139...
Listen guys... it takes all of about 10 brain cells to compile your own... there is a very simple GUI compiler over at BYOAC. It's not hard at all. If you do so, you'll also be compiling in high score support. It's easy. Give it a try.
I tried re-compiling it, using the info listed on mameworld and the mame compiler front end program on headsoft. Checked the box for "disable warnings as error". First tried to compile it with the MAME UI box checked, but it wouldn't work, so I unchecked it and it recompiled the program. But when I tried a game known for not being 100% accurate, the prompt came up, so it didn't work.
Guess I already damaged the 10 cells I need b/c I already tried to do that and couldn't get it to work, as I posted:
I think the hiscore version is compiled with the warnings disabled.
http://highscore.mameworld.info/download.htm
Have you tried this one yet?
