mc300baud
ok, so i've got this Midway Skins Game PCB that'll boot to the test menu if i put it in EPROM test mode. when i run the hard drive test it tells me there's no hard drive connected. if i run the file system test it tells me "Failure to mount file system / QIO error, EOF on file." if i try to boot the game normally it gives me the same or a very similar error.
i don't hear the HD spinning and i did test the voltages at the end of the HD power cable (+5v and +13v,) so it's not like it's not getting power. and i tested the PCB in two cabs (a dedicated Skins game and a generic JAMMA) and had the same result with both.
anything else i should check before i call this drive dead?
