Skewed image, rotate yoke?
Tighe
Richmondville, New York
The image on the K7000 (swapped in a TV tube and yoke) is slightly rotated on the tube. To fix this do I rotate the yoke? What is the recommended method for doing so?
Yeah, you need to rotate the yoke. With the power off, loosen the screw that holds it on so it moves easily -- then you can adjust it. I adjust it with the power on, just being sure to only touch the plastic housing. If you are worried about getting shocked, you can do it with the power off, but it will take a long time by trial & error. Once you get it right just tighten the screw again.
If the monitor is still in the cab you'll probably need to rig up a mirror to see what you are doing.
Yoke rotated! I still need to converge it, what is with the sucky test pattern on SHO? I will have to wheel it up next to my MK1 for a good pattern for converging this monitor.
