modessitt
I have been given the unfortunate task of installing a DBV into a Skeeball (newer Model-S I think) where the ticket dispenser normally is. The DBV's I'm told I will be given are Rowe CBA-2's. My research indicates these run on +12vdc, so I have to figure out where to get +12vdc. Obviously I could install a switcher in the back and run wires for it, but if there is already a source I can use, that would be preferable. This +12 needs to be present anytime the game is on.
And if anyone knows anything about these CBA-2's, the info I've found elsewhere seems to indicate I need to run +5 to the $1 Enable in order for it to take $1 bills, correct? And then I set the pulses via dip switch, wire up the Ground and Coin Sw, and it should work?
I don't know why they couldn't have given me easy Mars Series 2000's. Those are easy to hook up in an arcade application - no matter what type of game...
