skee ball lightning
trid
Michigan
Hello everyone im new to the whole arcade thing and was looking for some help. I have a skee ball lightning machine. It plays good the first time but it doesnt dispense tickets and when im finished it says code 0 on the kiosk. i tried calling skee ball and they were not much help i just wanna know what the code means so i can go from there.
any help would be much appreciated
thanks
travis
Code 0 means a ticket error....so that means one of the following:
1-Your ticket dispenser is bad or empty
2-The main PCB is bad
3-The cable between the the two is bad
-Mark
Thanks mark i thinkbi figured it out I found a wire going into the board that's just hanging so I'm gonna fix that and see how it goes
skeeball
If you do not have 100 point holes there should be two molex connectors dangling from the board... if you do not care about tickets you can program the game to dispense tickets at an unattainable score or disconnect ticket dispensor on the board dip switches... If you want tickets and are out you will get an error message at end of game or a flashing "call"
