G-P-E
Ok I traced all the wires by hand and using the schematics. All the
wires line up for connector J3 on the transformer board going to the
all the other boards. Except for one exception.
I have the transformer wire from a2j3-13 going to Solenoid Driver
board a3j3-5. The plug connector schematic says its supposed to go
from a2j3-13 to SOL. BUSS
I have no wire at a2j3-9. The plug connector schematic says its
supposed to go to a3j3-5, a8j1-9.
Thoughts? Would this cause my issue possibly?
Nope, not it ... but keep tracing.
A2J3-9 and A2J3-13 are the exact same signal on the rectifier board -- both are 43V out from the rectifier board. One goes to solenoid bus, other goes to relay (A3J3-5). If the two wires are reversed, it won't matter as they both come from the same place. However, for sake of tracing the machine at some later date - best to put the wires where the manual says they should be.
To me - it still sounds like a short between A3J3-5 and A3J3-6... somewhere. Not necessarily a short at the connector but somewhere in the wiring.
Ed
