Grbgemen
Figured i would start a new thread rather than add this to the display issue thread that i posted two weeks ago.
Got all the displays figured out and now I am on to the lamps. When we first powered this machine up, almost all of the G.I. lamps were dead. None of the CPU controlled lamps were working. I checked for power at the lamps and there was none. After i replaced the Bridge on the rectifier board, we had CPU lights.
Problem i am having is a lot of them are pulsing. They are on and get a little dim but never actually turn off. Some of the lights do turn on and off during attract as they should. For example, the S-K-A-T-E lamps should flash in sequence E-T-A-K-S. When it starts this sequence, it goes all the way through but the S is sort of flickering the whole time. I guess i dont know if this flicking/slight dimming is considered a locked on lamp. I also have a slight buzzing sound coming from some of the bulbs.
Also, during display test, a lot of the cpu lamps flash while the displays are counting from 0-9. That should not be happening right?
