72Demon
I have a upright Sinistar that previously had a CPU board issue. I got a replacement thru YellowDog here on KLOV. I was able to have the Sinistar up and running for about two days and now it has a vertical hold issue. On the Sinistar since it has a vertical oriented monitor the screen was rolling from left to right. It started off rolling fast in that direction. I adjusted the vertical hold and sometimes can get it to stop, but most of the time it will be off center as can be seen in the picture. I have adjusted the vert position but usually that will not adjust far enough to get back to center. It will start creeping again after a short time anyway. After every power up, it will be in a different spot, or rolling again.
The monitor is a WG 19K4951. I tried reseating the connections, did not help. Any suggestions would be greatly appreciated. Thank you for your help.
