who922
I am having problems with my Sinbad Pin. I am not a pinball repair whiz by any means. I do know how to repair things because I am a computer tech. A couple of things I would like some input on...and if possible, it would help me if you could answer with my limited knowledge in mind. And, yes, I have thought of having someone else llok at it, but the closest is 3 hours from me, so you see the logistical problem.
I have read about a ground repair for System 1 machines that really helps. Can someone tell me how to do this or point me in the right direction?
In 3 of the 4 banks of targets their are one or two targets that don't work. Therefore, I can only get double bonus and nothing more. It wasn't working when I bought it. When I got it home, the machine worked perfectly for that evening. The next day it didn't and hasn't since. Any ideas?
Finally, the right flipper is stuck in the up position once it is used. When you turn it off it goes back down until you turn it on and use it again and it sticks.
Thanks for the help. I really want to get it working well before I start other restorations.
