Simple stupid 4 pin connector help
StreetzKing
Donor 2013
Hyde Park, New York
I am trying to make a gun adapter with an existing harness I have no use for. I got a new set of guns that work for a different game and instead of swapping guns back and fourth I can just use this adapter. No one makes one, its for unico to happ (not the other way around)
Heres the info I have
http://arcarc.xmission.com/PDF_Arcade_Manuals_and_Schematics/Zero Point 2.pdf
Zero point 2 manual, page 10 shows the guns I have with these connections
-Gun Sensor (white)
-+5 (red)
-Trigger SW (green)
-GND (black)
http://arcarc.xmission.com/PDF_Arca...rce_Universal_Kit_(16-34032-101)_Feb_1988.pdf
Area 51 manual, shows how my guns are now kinda. page 34 shows the connectors, I only use 4 out of the 9. these 4:
-+5 (red)
-trigger (white)
-gnd (blk)
-scrsenc (blue)
So what I am asking is what wires am I splicing together on this adapter.
Is it red to red, white to white, black to black, and blue to green??
I made up a bunch of adapters a few years back for testing different guns on different systems. One of these days I should dig up my notes and post them somewhere.
You're already got things figured out. Forget wire color - it's what each wire does that counts.
+5 and ground should be matched to each, and trigger/sense be matched to each.
so trigger to trigger sw
and
gun sensor to scrsenc?
worst case scenario those are wrong?? nothing bad right since the +5 and gnds are right??
