Simple Green
derSturm
Permanently Banned
Apple Springs, Texas
Is Simple Green really the best cleaner for these machines, as many posts here would imply, or are you all just a bunch of hippies? :D
I love simple green, and I love greased lighting, magic erasers, scotch bright pads, rubbing compound, retr0bright, Meguiars cleaner wax, acetone...
Krud Kutter works great.. spray it on metal from inside a machine that's been in a bar, and you can watch the yellow/brown smoke+nicotene just dissolve and suds off.
I use Greased Lightning with a brillo pad to help remove rust and discoloration from metal parts then use Krud Kutter to remove the grease/dirt.
Never have a problem with either discoloring plastics.
Monitor plexi and marquees I use Novus to polish up after cleaning.
