Silverball Mania Self Test / Flipper
dlbuller
Michigan
I have a silverball mania self test question. I run the self test to the solenoid check. 1-9 work, but I can't figure out why 11 (flipper) won't. When the self test runs, and I hold in the flipper, it works fine. It's supposed to fire by itself right?
thank you for any help you can give me.
I couldn't remember if the flippers trigger with the self test on the solenoids, so I just ran it.....and no the flippers don't trigger. I guess the reasoning behind that is you can just see if they are working by using the flipper buttons.
It's not possible for the machine to energize the flipper coil without the cabinet button being pressed. If you hold in the flipper buttons during the solenoid test the flippers should energize when the MPU energizes the flipper relay. I wouldn't do that though. Not too good for the flipper relay contacts.
