Silverball mania random scoring
dlbuller
Michigan
I have a silverball mania machine that I have done some work on. It now seems to rack up points by itself. At first I thought it was just from the switches needing adjustment because it would add points when the flippers were activated.
Do I need to just make sure all the switches are adjusted properly again? Is there something else I should look at too?
Thank you for any help you can give.
Yep... those Bally switches have to be just perfect.
Throw her in switch test and see which one is registered closing.
+1 on testing which switch is stuck. If you start randomly adjusting switches and don't do it right you could be compounding the problem. Run it through test mode and start there.
