So I'm in the process restoring a Silver Strike cabinet. I purchased Silver Strike live complete kit from eBay that came with the matching CID board as well as the io board and Nighthawk computer. The cellar claims that everything was working prior to shipping and I trust with the amount of feedback that he had he is a trustworthy seller more than likely any errors at this point are my fault.
So I hooked up the I/O board to the Nighthawk via USB. The the io board is connected via Jamma. The CID board is also hooked up by USB. When I plug the power cord into the Nighthawk and fire it up a green light turns on the motherboard within the Nighthawk but I get no picture. None of the fans come on either within the Nighthawk. Initially I thought the power supply might be bad so I swapped it with the power supply in my Golden Tee live 2016 machine and it fired up my GT just fine. So I've eliminated the power supply being the issue. But I'm not sure where I'm going wrong from here.
I've included a video of what I've hooked up so far. If you can see something that is hooked up incorrectly please let me know I'm pretty anxious to get this up and running ASAP. Thanks guys, hope somebody can help me!!!
https://youtu.be/FMvtLwLA7sc
