Silver Strike Bowling - Nighthawk system box (and hard drive?)
Looks like you have everything needed except the power supply and the hard drive. You can call IT and get these on the way. I believe the hard drive is 125 and the ps is around 45.
Clay
Do I need the power supply if I'm going to be plugging it into a working Golden Tee cabinet? I'm trying to run a 2-in-1 with Golden Tee Fore 2003.
i would plug the board in to see if it tries to boot
if it doesn't you may need a motherboard also
You will need an ATX power supply. The golden tee power supply will not hook up to the silver strike bowling motherboard or hard drive.
