Silver strike bowling error message
MChandler
Moseley, Virginia
I have a silver strike bowling game . Have had for about a year now. No problems until now. It stopped working fans would not turn on. LCD screen I have hooked up had no signal. I read on another forum to remove and reinstall battery. I did this and moniter started working. But not when it boots I get an error message.. looks like something with soundcard not being found. I will post picture below. If this is the case I am not worried about sound. Can I bypass this or is something else wrong. Any help would be appreciated.
When you replace the battery the motherboard goes back to default settings. Check in the bios that sound is enabled. I'd replace the drive if everything is on.
