Hi guys, I am doing some repair work and need to run a jumper wire from a chip leg to a resistor. I've seen people use a clear goo on the solder joint between the chip leg and the jumper wire, is this regular clear silicone or something special? I have some clear silicone sealant that I've used in the house, not sure if this is the right thing...
Thanks,
P
Thanks,
P
