SiLeNtNiNjA1
I have acquired a couple silent scope machines, and both have parts of the wiring harnesses ripped apart. It dosnt help when someone has replaced a section with several yellow wires all together rather than following the colors on the other side of the harness, then pulled them apart again. For one machine im looking for the pinout to the connector from the gun position board (where the pots are running to) and on the other, the wires actually running up into the gun. I tried going over the pdf manual I found online, but it was way to blurry. Does anyone have either higher resolution scans if that section, a manual with the wiring section in the end theyd like to sell, or a machine to take a peak at and give me something to match?
