I have been fighting the Wizard of Wor side art set to stay stuck for over 2 months now... and I am fighting a losing fight. The left side rear toward to the bottom continuously lifts after a day or so of being stuck... and the right side back side also comes up slightly...but not nearly as bad. I've had adhesion issues from the get-go but was told by Darrin that since each side comes from a different batch, it "had" to be me and not his product. He suggested Super 44 (I think that was what it was called)... but I seem to remember Pr0k saying to never use that product. At first the adhesion issue was major....about 50% of the left side and 25% of the right side came up some 24-36 hours after installation. That is when I contacted Darrin. After his suggestion I figured I'd give it one more try ...perhaps I didn't press hard enough, etc... I spend a good 10 minutes per side really pressing down in an attempt to get the side art to stay stuck...I covered every square inch of the side art and it seemed to work. About 3 days later I noticed the issue with the left side...but it was minor...maybe 2 to 3 inches of the back bottom coming maybe a half inch in. The right side stayed stuck. Over the last couple months that very same area had continuously come unstuck no matter how hard I try to press it on there... I'll press...it will stay....hours later it's fine... a day or two later it's up again. The right side takes days to come up, but it eventually does. I've not been in my gameroom in about a week or so and when I checked today the back bottom of the left was unstuck about 4" up and about 2" in...it's getting worse. The right is about the same as usual... very minor along the edge.
The side art was applied to a freshly painted cabinet...days after the paint dried. I told Darrin it was oil-based paint as I usually use oil based paints on my cabs, but that was incorrect... because I matched the color of the control panel artwork, I had to go with latex as that is all they offered for color matching.
What are your opinions in regards to how to keep this freakin' side art stuck? Should I go with the Super 44 stuff? Is there another option? The last time around I tried using a rolling pin to press it down and, well, here we are... should I try to use a hair dryer to warm up the artwork/glue and press? I'm getting a little irked at this and I am sure every time the damn art comes up the glue is getting more and more contaminated with air particles, etc. I just want it to stick for crying out loud.
Help!
Help!
