andykmv
i am looking for a Midway Power Supply board model A082-90400-H000, to go with the matching SI harness** and matching Midway SI L Shaped boardset, and i am having more luck finding everything but that model (missed out on an ebay item recently).
**they both have the Amphenol/Tyco Miniature Rectangular 24 pin connectors - the PCB has the 24 pin "PC Board Vertical
Pin Header" part no 640505-3 (could be the -1 if thinner pcb), and the harness has the part no 1-640525-0 line socket. i would need to get the matching part no 1-640515-0 "pin housing" and pins to make an inline adapter. See Digikey catalogue page http://dkc3.digikey.com/PDF/US2011/P0252.pdf for the parts.
so i have started looking at original power supply boards of similar era as an alternative as i would rather be a masochist and at least get CLOSE to original than put in a switcher!
does anyone have waveform traces of any or all of the 12v line, 5v line, Reset and Sense circuit waveforms of volts vs time during the power supply startup phase, upto and including the 5v rail/reset line stabilising ? useful to check//verify compatibility. From what i have read so far, the pcb wont boot unless there is a working reset circuit.
So far i have looked at the compatibility of :
- the Galaga Power Supply board model A084-90414-C935
SilentNinja has one for sale at the moment. after comparing the schematics for both the A084-90414-C935 (ref the Midway Galaga schematics) and the A082-90400-H000 (re f the Midway SI schematics), i could make up a harness adapter and hack up a reset circuit, but are the Sense circuits compatible ?
