Shoring up a Williams cabinet
Chomulus
Pittsburgh, Pennsylvania
I have a Firepower, about to get started working on it. The bottom panel is solid. It just seems like the corners are lose. Has anyone used any sort of bracing to pull a cabinet true?. I can lift the playfield. It's not that janky.
have repaired many a cracked out pinball cabinet, i use pipe clamps and a framing square
pull playfield & remove head then .....
replace broken blocking as needed (cut news ones as needed), i use titebond 2 wood glue, crown stapler where needed, its very important to level the cabinet before clamping and glue are applied
those cabinet protectors are pretty awesome for protecting fresh paint & newly decal-ed cabinets
depending upon cabinets internal corner bracing one may or may not be able to use the heavy duty leg bolt plates - they are nice tho, but i have seen situation where the only way to install a set would be to remove the original corner blocking (dont recall which cabinet that was)
The leg mount replacement might solve the issue. I also might have to cut some blocks and glue staple in to the corners.
The only way I can describe it is it's as if the cabinet is lose?
Thanks all of you for the suggestions I will check the leg bracings this week!
