Sharp XM-2100N Degauss Connector
MackAttack
Donor 4 years: 2014, 2016, 2018, 2024
This 2-pin degauss connector got a little cooked & brittle over the years. I need help identifying and sourcing a replacement. It works fine as is, but I would like to replace it if possible.
This is a Sharp XM-2100N chassis from an Atari Assault machine I picked up over the weekend.
measure the center to center spacing and also the pin diameter to confirm as they should be 7.5mm spacing and 1.55mm diameter and if so here is the correct parts but if different we will have that also so let me know.
CN1001, CN1008 and CN1006 is what you want if the sizes match up.
