Ohmerone
All the SI 3XX are different
SI-327,SI-327SV-JS, Etc
Different parts Locations #
I have a Vigin chassis 80% cap tested bad.
After cap kit same symptom
you hear deguasser relay click then
B+ stays up and no picture no hv.
Vertical ic was causing the problem
replaced Ic501 Tda8172 could smell something
over heating.at that point you could remove the solder from the Vertical Ic
or remove the Ic then should have HV and a horizontal line,then you will know
that the Vertical ic was causing HV shutdown.
