sharp image si-727r (need iso or not??)
monster kong
California
25" dual res monitor
sharp image
si-727r-ds
does this monitor need an isolation transformer?
You can USUALLY tell (read: not always, just for murphys sake) if the monitor needs an ISO by seeing if it has a switch mode power supply. Look on the board near where the power goes in, if you see a transformer that looks like a smaller version of an ISO mounted on the board, you probably dont' need an ISO.
Also, to be safe you could always use one. Doesn't hurt anything.
