Problem areas:
#1: Looks like a cold solder joint on the "right" side of C606. Refresh and reflow solder there, remove old and place new.
#2: These chassis have un"protected" traces in between capacitors as you see here. It looks like the bottom joint of C610 may be touching the trace running between the cap. Make sure there is no continuity from either leg of the cap to that middle piece.
#3: R901 has gotten hot and burned a little of the trace going from pin 7 on the flyback. Check resistance between the two points there just to make sure it's a complete short (should be less than an ohm, very close to zero. If it is not, clean off the soot, remove a little of the trace, and blob solder from that leg of R901 to the trace just to ensure it's getting a good connection. (may not be your problem, but could be in the future.)
#4: It looks like the right leg of C702 is touching the left joint of the jumper MKL was talking about, J8. Bend back and make sure there is no continuity there.
#5: Not sure what this component is, however the top 2 legs on the left look like bad solder joints. Refresh and reflow solder there, remove old and place new.
#6: (Just below D605) Oh that's T601. I don't think the 3rd leg from the left should be soldered to the leg to the right of it, but it is possible. Did you do that, or did it come like that?
Lower right hand side (forgot to number), it looks like that is R904, is it supposed to be on the bottom? And it looks like cold solder joints there as well. I'd put it on top if you could, or at least refresh the solder joints.
MKL is an excellent troubleshooter, try to answer his questions also with as much vigor as you've been answering mine.
