Sharp Image KTM-F
SilverDuck
Minnesota
Is the Sharp Image KTMF able to run std res? If so, how do you switch it? Anyone have a manual?
If you're talking about this one, then it is CGA (standard res). While it may have been used by Sharp Image, it was made by Kortek...
Mine looks like this:
It was sold to me as a med res monitor. I have not yet messed with it.
That looks an awful like the SI-325:
I don't have a manual or schematic handy, but check those connectors in the middle of the chassis. If one is labeled 15K (standard) and one is labeled 25K (medium), then it a dual res 25" monitor chassis which needs to match the proper yoke to work. Don't switch the res plug while powered on...
