Sharkey's shootout parts
gobsgraham
AB, Canada
So I am going to attempt to rebuild this machine. I have been able to find most of the missing parts at Marco but can't seem to be able to find the IO driver board Pinball 520-5137-64.
Does anyone know where I can find one of these or have one to sell? I am looking for a bunch of other parts too so if you have the others I need also I will buy them from you instead of Marco.
8-Ball Launcher assembly
Right Flipper assembly
rubber kit
glass
Thanks for the reply. The link doesn't seem to work for me though. I found a document with the modifications but I think it was referencing a modified version of the -64. The picklist had the -64 part number and then not stuffed beside all the parts that are to be removed to work with the IT tournament stuff.
I could be completely wrong so if anyone does know for sure or has either board for sale please let me know.
So I finally got around to working on this a bit. I have almost all of the glass out of it and installed the Rottendog replacement driver board for it. I am happy to report that the game plays and from what I can tell everything is working. This will not become the Virtual pin that plan B had in mind for it. There were a few more pieces missing than I thought so I am slowly putting it back together.
So far:
Cleaned all broken glass
Installed Rottendog board
Tested all voltages
played around with one flipper and my hand to try and test all the switches, shots, magic 8-ball.
Still to do:
Install missing flipper assembly
Install missing ball kickout coil
Install 8-ball shooter assembly
Clean/wax playfield
Full rubber kit
New pinballs
New glass
put the legs on and bring it into the house.
Play pool er um pinball.
try not to get too turned on by Ginette Lee telling me how good I am with my stick.
I have finally finished fixing up this machine. Everything is working fine except the sound is a bit scratchy and one of the ramps has broken away from the clip that holds it down in the middle. Overall I am pretty happy with it and it plays pretty good.
